Введение
Hello! This is a guide on how to replace the front-facing camera and light sensor in your Vizio VTAB1008.
Выберете то, что вам нужно
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
Look into the tablet for loose connectors.
Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
Remove the screw with the J1 screwdriver or screw bit.
Lift the flap hiding the second screw.
Remove the screw by using the J1 screwdriver.
Disconnect the ribbon cable from the camera circuit board by lifting it away from the circuit board.
