Введение
This guide is good for almost all volleyball brands. Volleyball is ranked 6 in the world for most played sport for it adrenaline rush during the game with amazing saves and hard hitting spikes. However, when playing volleyball, the amount of the times the ball is hit can move or damage the air valve inside the ball which can cause air to leak out from the volleyball. If your volleyball seems to always deflate, this guide can help restore the volleyball to like-new.
Выберете то, что вам нужно
Insert the wire into the valve and use it to hook and pull out the valve as much as possible. .
Once a piece of the valve is sticking out, use the needle nose pliers to pull out the valve.
You are done! The volleyball valve has been replaced and should not let any air out.
Один комментарий
Thanks for this!!
Can you please let me know what valves to buy?
(my email address is sendtojfk@gmail.com)
Thanks!
