Введение
The Vornado 133 has a small fuse in the plug end as a safety feature; if the fuse has burnt out, your fan will not start. This guide will illustrate how to remove and replace the fuse.
Выберете то, что вам нужно
Slide open the fuse access cover on the top of the plug by moving it towards the end of the plug.
Use a pair of tweezers or a small plastic spudger to remove the fuse from the fuse casing. Remove the end nearer to the fan body first, then the end nearer to the plug end.
Follow these instructions in reverse order to install the new fuse and close the access panel.
11 участников успешно повторили данное руководство.
10 Комментариев
Great post! This saved me $60 from buying a new fan! Thank you!
Thanks for posting. Ordered a pack of 50 fuses from amazon for $7.97
Fast-acting or slow-acting?
The fuse isnt clear glass its red strip white under what that mean
The fuse is not clear it has whitestrip with red strip what that
I replaced the fuse and still will not turn on. Ive only had the fan for 6 months
