Введение
In this replacement guide, step by step instructions will show how to replace the circuit board located inside of the Vornado Duo.
Выберете то, что вам нужно
Start off by using a Philips #2 screwdriver to remove all 8 10mm exterior screws on the rear of the device.
Remove fan blade after unscrewing top 2 screws located on each side of the covered board.
Unsolder the circled spots on the mother board and resolder each wire to corresponding spot.
2 участников успешно повторили данное руководство.
