Введение
Headphones do not work when you plug them into the InnoTab? This guide will walk you through replacing the headphone port on your childs Vtech InnoTab 3S.
Выберете то, что вам нужно
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
Using a nylon spudger, remove the five caps that hide the screws.
Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
