Введение
This guide will walk you through replacing the USB port on your childs Vtech InnoTab 3S.
Выберете то, что вам нужно
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
Using a nylon spudger, remove the five caps that hide the screws.
Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
Remove the six 3 mm screws securing the battery clip.
Facing the underside of the USB port, solder the metal prongs securing the USB port to the device.
