Vtech InnoTab 3S USB Port Replacement
Выберете то, что вам нужно
  1. Vtech InnoTab 3S USB Port Replacement, Rear Panel: шаг 1, изображение 1 из 3 Vtech InnoTab 3S USB Port Replacement, Rear Panel: шаг 1, изображение 2 из 3 Vtech InnoTab 3S USB Port Replacement, Rear Panel: шаг 1, изображение 3 из 3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S USB Port Replacement: шаг 2, изображение 1 из 2 Vtech InnoTab 3S USB Port Replacement: шаг 2, изображение 2 из 2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S USB Port Replacement: шаг 3, изображение 1 из 3 Vtech InnoTab 3S USB Port Replacement: шаг 3, изображение 2 из 3 Vtech InnoTab 3S USB Port Replacement: шаг 3, изображение 3 из 3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S USB Port Replacement: шаг 4, изображение 1 из 1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S USB Port Replacement, Motherboard: шаг 5, изображение 1 из 2 Vtech InnoTab 3S USB Port Replacement, Motherboard: шаг 5, изображение 2 из 2
    • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
    • Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
    • Remove the six 3 mm screws securing the battery clip.
  6. Vtech InnoTab 3S USB Port Replacement: шаг 6, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
    • With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
    • Potential for device damage: Avoid forceful movements when removing the motherboard to prevent damage of device components.
  7. Vtech InnoTab 3S USB Port Replacement, USB Port: шаг 7, изображение 1 из 3 Vtech InnoTab 3S USB Port Replacement, USB Port: шаг 7, изображение 2 из 3 Vtech InnoTab 3S USB Port Replacement, USB Port: шаг 7, изображение 3 из 3
    • The mini USB port is located near the top of the device and is secured by four metal prongs underneath the port.
    • Facing the underside of the USB port, solder the metal prongs securing the USB port to the device.
    • Avoid forceful movements when soldering to prevent damage of device components and avoid personal injury.
Заключение
2 человек успешно провели ремонт по этому руководству.
taweewatchulikavit
Участник с: 08/27/15
398 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 8-2, Eyestone Fall 2015 Участник USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 членов
Автор 9 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 1,441
