Введение
Battery dead, or not holding a charge? Follow this guide to replace it with a new one! Note: This guide requires soldering.
Выберете то, что вам нужно
Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
Using the plastic opening tool, gently pry the edges of the battery away from from the circuit board.
Pull the battery free, and wait for the solder to cool before handling further.
6 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Where did you bought the battery?
