Выберете то, что вам нужно
Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
Lift directly up to remove the switch and lay the wire down to the side.
Once the switch has been taken out you can remove the switch's casing.
Еще один человек закончил это руководство.
2 Комментарии к руководству
Good work.
I have done it the same way,
the wire at the switch was bad soldered,
but it was easy to repair it and i soldered it new.
Nice.
My baby’s phone keeps turning itself off. The switch is in the ON position but it keeps turning OFF and singing the off song. I have opened the phone and even held the switch to ON but it still keeps turning OFF even without the switch moving. Any suggestions?
