Wacom Cintiq 24HD USB Accessory Port Replacement
Выберете то, что вам нужно
  1. Wacom Cintiq 24HD USB Accessory Port Replacement, Stand: шаг 1, изображение 1 из 1
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
  2. Wacom Cintiq 24HD USB Accessory Port Replacement: шаг 2, изображение 1 из 3 Wacom Cintiq 24HD USB Accessory Port Replacement: шаг 2, изображение 2 из 3 Wacom Cintiq 24HD USB Accessory Port Replacement: шаг 2, изображение 3 из 3
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
  3. Wacom Cintiq 24HD USB Accessory Port Replacement: шаг 3, изображение 1 из 1
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
  4. Wacom Cintiq 24HD USB Accessory Port Replacement, Back Panel: шаг 4, изображение 1 из 3 Wacom Cintiq 24HD USB Accessory Port Replacement, Back Panel: шаг 4, изображение 2 из 3 Wacom Cintiq 24HD USB Accessory Port Replacement, Back Panel: шаг 4, изображение 3 из 3
    • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
    • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
    • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
    • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
  5. Wacom Cintiq 24HD USB Accessory Port Replacement: шаг 5, изображение 1 из 2 Wacom Cintiq 24HD USB Accessory Port Replacement: шаг 5, изображение 2 из 2
    • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
    • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
    • The latches on the back panel will make loud clicking noises when opening.
    • Remove the panel by lifting it up and off of the device.
  6. Wacom Cintiq 24HD USB Accessory Port Replacement, USB Accessory Port: шаг 6, изображение 1 из 3 Wacom Cintiq 24HD USB Accessory Port Replacement, USB Accessory Port: шаг 6, изображение 2 из 3 Wacom Cintiq 24HD USB Accessory Port Replacement, USB Accessory Port: шаг 6, изображение 3 из 3
    • Remove one 8mm Phillips #2 screw by turning the screwdriver counterclockwise
    • Remove one 9.9mm Phillips #2 screw by turning the screwdriver counterclockwise.
  7. Wacom Cintiq 24HD USB Accessory Port Replacement: шаг 7, изображение 1 из 2 Wacom Cintiq 24HD USB Accessory Port Replacement: шаг 7, изображение 2 из 2
    • Remove the black grounding wire by lifting up.
    • Remove the USB port board by pinching the wiring close to the connector and gently pulling out.
  8. Wacom Cintiq 24HD USB Accessory Port Replacement: шаг 8, изображение 1 из 1
    • Remove the USB port by melting the soldered connections with a soldering iron, then pulling the port off of the board.
    • iFixit has a guide to soldering which you can find here.
Заключение
Еще один человек закончил это руководство.
Andrew Fleming
Участник с: 10/08/18
408 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S15-G3, White Fall 2018 Участник Cal Poly, Team S15-G3, White Fall 2018
CPSU-WHITE-F18S15G3
4 членов
Автор 18 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 1,151
