Введение
The power switch connects the device motor to the power cord. If the power switch becomes broken or worn, the device may not function properly.
Выберете то, что вам нужно
Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
Remove the 13.0 mm Phillips #2 screw on the side of the device body.
This screw is located on the opposite side of the body from the switch.
Remove one 7.5 mm JIS #1 screw connecting the power cord to the switch base.
