Введение
Cord problems are bound to eventually happen due to normal use, winding up the cord, and cramming it into a drawer. The cord replacement process is straight forward, but the most important part to remember is do not work on device while it is plugged in. It is also advisable to take advantage of the open device by cleaning out any visible debris.
Выберете то, что вам нужно
Unscrew the three 12mm black JIS screw found on the red side of the the device with a JIS #1 driver.
Unscrew the 5.556mm screw with a JIS #0 screwdriver. (Black Screw located at power switch)
Инструмент, используемый на этом этапе:Spudger$2.99
Insert the metal spudger between the wire connector and the device connector. The spudger should disengage a tension-like lock between both connectors, and once disengaged gently pry out the cord connection.
To reassemble your device, follow these instructions in reverse order. When installing new cord, make sure black wire is underneath the white wire.
3 участников успешно повторили данное руководство.
