Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Hello all, today we will repair a water damaged phone.
it's a simple cell phone and quite easy to repair.
enjoy
Запчасти
Детали не указаны.
  1. Remove back cover & battery. Remove back cover & battery. Remove back cover & battery.
    • Remove back cover & battery.
  2. Remove the front case by prying it open. You will hear clicks. Be careful with taking off screen if you use a spudger.
    • Remove the front case by prying it open. You will hear clicks.
    • Be careful with taking off screen if you use a spudger.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  4. Use a Torx screwdriver to remove the screen screws. Use a spudger or tweezers to remove the connector of the LCD screen.
    • Use a Torx screwdriver to remove the screen screws.
    • Use a spudger or tweezers to remove the connector of the LCD screen.
  5. Remove keyboard by prying it open with a spudger. The keyboard is secured with adhesive, be careful! The keyboard is secured with adhesive, be careful!
    • Remove keyboard by prying it open with a spudger.
    • The keyboard is secured with adhesive, be careful!
  6. The PCB board had water damage, see this in picture 3. To remove the corrosion, dab a cotton swab with a little distilled water on the corroded area, the corrosion will disappear. To remove the corrosion, dab a cotton swab with a little distilled water on the corroded area, the corrosion will disappear.
    • The PCB board had water damage, see this in picture 3.
    • To remove the corrosion, dab a cotton swab with a little distilled water on the corroded area, the corrosion will disappear.
  7. How and where to use the cotton swabs. How and where to use the cotton swabs.
    • How and where to use the cotton swabs.
Заключение
15 участников успешно повторили данное руководство.
Kevin D
Участник с: 02.05.2014
6 532 Репутация
Автор 21 руководств
Комментариев: 3
no use .it is not switching on . replaced with good batter also. no on
nabhan75 - Ответить
try to clean with an ultrasonic bath.
measure out powerrail.
measure out the voltage coming in on board. try to see if you have short.
Kevin D - Ответить
Nokia 206 display and charger pin
Mithilesh Yadav - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 19
За всё время: 10,045
