Waterproof iPod Shuffle 4th Generation DIY Technique
Выберете то, что вам нужно
  1. Waterproof iPod Shuffle 4th Generation DIY Technique, Waterproof iPod Shuffle 4th Generation DIY Technique: шаг 1, изображение 1 из 1
    • To start you need the items as pictured. To the right is the waterproof dipping liquid bottle from Nanostate called Flash Flood Green Label, it's 3ml.
  2. Waterproof iPod Shuffle 4th Generation DIY Technique: шаг 2, изображение 1 из 1
    • You will need to use your ipod shuffle box to complete the waterproofing. If you don't have one you can use any plastic box or even a plastic bag as the coating is non toxic and non hazardous.
  3. Waterproof iPod Shuffle 4th Generation DIY Technique: шаг 3, изображение 1 из 1
    • Place your ipod shuffle inside the case and pour the liquid coating in.
  4. Waterproof iPod Shuffle 4th Generation DIY Technique: шаг 4, изображение 1 из 1
    • Place the lid on top and shake gently from left to right for 3 minuets.
  5. Waterproof iPod Shuffle 4th Generation DIY Technique: шаг 5, изображение 1 из 1
    • Take out the iPod shuffle after the 3 mins and dry with a microfibre cloth. Leave to dry for 3 hours before use.
  6. Waterproof iPod Shuffle 4th Generation DIY Technique: шаг 6, изображение 1 из 1
    • Again, from right to left cover the earphones & jack with the liquid coating for 3 mins. Take out and dry and do not use for 3 hours.
  7. Waterproof iPod Shuffle 4th Generation DIY Technique: шаг 7, изображение 1 из 1
    • After the 3 hours drying period, drop your iPod shuffle and earphones in the water for as long as you want ! It's tried and tested and works although you feel your heart stop when you drop it in !
Заключение
2 участников успешно повторили данное руководство.
myemail
Участник с: 07/15/13
137 Репутация
1 руководство автора
4 Комментариев
Nanostate appears to be a scam. I've tried to order this twice, under different names and to different addresses. Both times, the product never shipped, and a refund was issued only after repeated requests for information from the company. Don't waste your time.
Shawn Perdue - Ответить
Shawn you purchased and said you never got the product, got refunded and then you ordered again in your wife's name and the order was cancelled as that looked like a fraudulent transaction and due to the same uncommon surnames. Why would you reorder again in a different name ?
Order Date : 2013-08-22
Shawn Perdue
Order Date : 2013-11-08
Christin Perdue
A scam is when someone takes your money or the product does not work, neither has happened to you.
myemail - Ответить
is this product still available? I have tried the website but it doesn’t load
carol caputo - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 16
За последние 30 дней: 40
За всё время: 3,463
