Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement
Выберете то, что вам нужно
  1. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Unlock your door and open it.
    • Make sure the bolt/latch is fully inside the door before you continue.
  2. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: шаг 2, изображение 1 из 1
    • Using the Phillips #1 screwdriver, remove the three 8 mm screws on the left, right and bottom side of the cover.
  3. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: шаг 3, изображение 1 из 1
    • Take the exterior cover off of the door lock.
  4. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: шаг 4, изображение 1 из 2 Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: шаг 4, изображение 2 из 2
    • Find the battery pack (marked "DOOR" in between two arrows) at the top of the lock.
  5. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: шаг 5, изображение 1 из 2 Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: шаг 5, изображение 2 из 2
    • Slide the battery pack upwards.
    • Turn the pack over to reveal the batteries.
    • Replace the four AA batteries.
  6. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: шаг 6, изображение 1 из 1
    • Reinsert the battery pack with the word "DOOR" facing you.
    • Wait until you see a green LED light flashing and/or hear two beeps to indicate working batteries.
    • If there is no green light, repeat steps 5 and 6. Check to see if the batteries are placed correctly or if newer batteries are required.
  7. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: шаг 7, изображение 1 из 1
    • Check that the bolt/latch is still inside the door.
    • Take the exterior cover and point the narrow end of the knob to the right.
    • Place the cover on the lock and reinsert the screws.
    • Try not to fasten the screws too tightly as they could get damaged in the process.
  8. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: шаг 8, изображение 1 из 2 Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: шаг 8, изображение 2 из 2
    • To confirm the finished repair, go to the front of the door and place the back of your hand on the touchscreen to activate the keypad.
Заключение
Congratulations! Make sure to redo this process each year to ensure your device continues to work!
2 участников успешно повторили данное руководство.
Brandon Brown
Участник с: 05/15/21
214 Репутация
1 руководство автора
Команда
York University, Team S1-G7, Melo-Thaiss Summer 2021 Участник York University, Team S1-G7, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G7
1 член
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 33
За последние 30 дней: 163
За всё время: 7,558
