Well Pump Pressure Switch Replacement
Выберете то, что вам нужно
    • Here is a time lapse of what the pressure gauge showed. The pressure switch did not cutoff and rising pressure caused some faucets to develop leaks.
  1. Well Pump  Pressure Switch Replacement: шаг 2, изображение 1 из 3 Well Pump  Pressure Switch Replacement: шаг 2, изображение 2 из 3 Well Pump  Pressure Switch Replacement: шаг 2, изображение 3 из 3
    • WARNING: The switch is supplied with 220V so one has to be careful not to get zapped. The first thing before doing anything is to flip the breaker to the pump switch and check it with a meter to ensure it is off.
    • Remove the small nut from the cover to gain access to the switch.
    • With the cover removed, check for power across the switch from supply lines L1 and L2 (Blue marker). Ensure that there is 0 volt.
  2. Well Pump  Pressure Switch Replacement: шаг 3, изображение 1 из 3 Well Pump  Pressure Switch Replacement: шаг 3, изображение 2 из 3 Well Pump  Pressure Switch Replacement: шаг 3, изображение 3 из 3
    • Close off the water supply to the dwelling by turning the gate valve to the right side.
    • Next drain the tank and the supply line by opening the valve. Each installation could be different, depending on ow and where it is installed. Any installation should have a shut-off valve and a drain valve somewhere before entering the dwelling.
    • Loosen the 4 screws that hold the wires to the switch
    • The ground screw on the bottom of the switch shares the ground from the supply line and from the pump. Remove those as well.
    • With the wires removed from the switch and the water line drained, remove the switch from the nipple attached to the check valve. Use a suitable wrench like an adjustable or in this case a pipe wrench
  3. Well Pump  Pressure Switch Replacement: шаг 4, изображение 1 из 3 Well Pump  Pressure Switch Replacement: шаг 4, изображение 2 из 3 Well Pump  Pressure Switch Replacement: шаг 4, изображение 3 из 3
    • It became immediately obvious that the nipple was almost completely corroded of the check valve. It broke off while attempting to remove the pressure switch.
    • After the use of a couple of choice words and cleaning the damage on check valve, it turned out that the thread was not damaged.
    • In this case the nipple needs to be replaced as well. The bottom one is the corroded one and the top is the new one.
    • Corrosion and debris on the inside of the nipple show that it is almost entirely occluded.
  4. Well Pump  Pressure Switch Replacement: шаг 5, изображение 1 из 3 Well Pump  Pressure Switch Replacement: шаг 5, изображение 2 из 3 Well Pump  Pressure Switch Replacement: шаг 5, изображение 3 из 3
    • Here is the inlet to the pressure switch. Again visible is the large amount of corrosion and debris from the corroded nipple. this is what most likely caused the pressure switch to fail.
    • Apply some thread sealing tape before installing the new nipple. Apply the tape in a clockwise direction.
    • Install the nipple into the check valve. Use a small pipe wrench to fasten it.
  5. Well Pump  Pressure Switch Replacement: шаг 6, изображение 1 из 3 Well Pump  Pressure Switch Replacement: шаг 6, изображение 2 из 3 Well Pump  Pressure Switch Replacement: шаг 6, изображение 3 из 3
    • Next apply thread sealing tape to the top of the nipple. Again apply in clockwise direction.
    • Next install the new pressure switch
    • Use a pipe wrench or adjustable wrench to fasten the pressure switch
  6. Well Pump  Pressure Switch Replacement: шаг 7, изображение 1 из 2 Well Pump  Pressure Switch Replacement: шаг 7, изображение 2 из 2
    • Connect the power wires and the pump wires as directed. Most pressure switches have a small diagram on the inside of the cover. Some switches have the contacts labeled as L1&L2 for the power lines and T1&T2 for the pump wires.
    • All that is left now is to reapply the cover and to open the gate valve of the water line to the dwelling. Flip fuse(s) back on and the pressure switch should kick in.
Заключение
Straight forward task accomplished with just a few basic tools.
Еще один человек закончил это руководство.
oldturkey03
Участник с: 09/29/10
837 434 Репутация
Автор 123 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 14
За последние 30 дней: 78
За всё время: 22,135
