Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
In this guide the reader will learn how to properly replace the fender on a western saddle. The repair will require a new saddle fender. It is easiest to perform this replacement while using a saddle stand, but it is not required.
  1. Unbuckle the fender.
    • Unbuckle the fender.
  2. Remove the stirrup from the fender.
    • Remove the stirrup from the fender.
  3. Pull on the fender leather to remove the fender from the saddle.
    • Pull on the fender leather to remove the fender from the saddle.
  4. Remove the hobble and blevins from the new stirrup. Remove the hobble and blevins from the new stirrup.
    • Remove the hobble and blevins from the new stirrup.
  5. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Run the new stirrup leather over the bar. Run the new stirrup leather over the bar. Run the new stirrup leather over the bar.
    • Run the new stirrup leather over the bar.
  7. Bring the fender leather out on the underside of the saddle. Bring the fender leather out on the underside of the saddle.
    • Bring the fender leather out on the underside of the saddle.
  8. Push the leather back under the bar over the rigging. Push the leather back under the bar over the rigging.
    • Push the leather back under the bar over the rigging.
  9. Pull the stirrup leather tight.
    • Pull the stirrup leather tight.
  10. Put stirrup, blevins, and hobble back on the new stirrup. Put stirrup, blevins, and hobble back on the new stirrup.
    • Put stirrup, blevins, and hobble back on the new stirrup.
  11. Slide the blevins over the stirrup holes. Slide the blevins over the stirrup holes.
    • Slide the blevins over the stirrup holes.
  12. After the fender is fixed the saddle should be ready to ride.
    • After the fender is fixed the saddle should be ready to ride.
Заключение
The fender is replaced and you are ready to ride!
3 участников успешно повторили данное руководство.
Mackenzie Pagliai
Участник с: 30.09.2016
185 Репутация
1 руководство автора
Команда
Missouri Western, Team 1-9, Adkins Fall 2016 Участник Missouri Western, Team 1-9, Adkins Fall 2016
MWSU-ADKINS-F16S1G9
3 членов
Автор 1 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 67
За всё время: 3,795
