Выберете то, что вам нужно
Using a plastic opening tool, remove the four small foam pieces on the bottom of the fan.
Remove the four screws that were uncovered in the previous step.
Remove the bottom cover using a spudger if needed.
Remove the two middle screws connecting the air filter casing to the front casing.
Remove the front casing.
Put the new air filter casing in place after cleaning the filter.
Repeat steps 1-9 in reverse order to properly put back together the fan.
Еще один человек закончил это руководство.
