Введение
This guide will show you how to remove the plastic casing so that it can be replaced.
Выберете то, что вам нужно
Remove the knob by gripping it and pulling straight up. Use a spudger if it is difficult to grip.
Using the plastic opening tool, turn the device over and remove the black plastic covers over the four screw holes.
Remove 5 smaller screws visible through small holes between the base and the casing.
Remove the two screws attached to the white bar near the red light on the top of the front casing.
Еще один человек закончил это руководство.
