This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Why! NH57ADS Fan and Heatsink Removal
Выберете то, что вам нужно
  1. Why! NH57ADS Fan and Heatsink Removal, Battery: шаг 1, изображение 1 из 3 Why! NH57ADS Fan and Heatsink Removal, Battery: шаг 1, изображение 2 из 3 Why! NH57ADS Fan and Heatsink Removal, Battery: шаг 1, изображение 3 из 3
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery and lift to remove it.
  2. Why! NH57ADS Fan and Heatsink Removal, Bottom Cover: шаг 2, изображение 1 из 3 Why! NH57ADS Fan and Heatsink Removal, Bottom Cover: шаг 2, изображение 2 из 3 Why! NH57ADS Fan and Heatsink Removal, Bottom Cover: шаг 2, изображение 3 из 3
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the catches holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS Fan and Heatsink Removal, Removing the Bottom Cover: шаг 3, изображение 1 из 3 Why! NH57ADS Fan and Heatsink Removal, Removing the Bottom Cover: шаг 3, изображение 2 из 3 Why! NH57ADS Fan and Heatsink Removal, Removing the Bottom Cover: шаг 3, изображение 3 из 3
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Lift the bottom cover to remove it.
  4. Why! NH57ADS Fan and Heatsink Removal, Fan: шаг 4, изображение 1 из 3 Why! NH57ADS Fan and Heatsink Removal, Fan: шаг 4, изображение 2 из 3 Why! NH57ADS Fan and Heatsink Removal, Fan: шаг 4, изображение 3 из 3
    • Remove the three Phillips screws securing the fan on the right.
    • Carefully unplug the fan's power connector.
    • Remove the first fan.
  5. Why! NH57ADS Fan and Heatsink Removal, Fan and Heatsink Assembly: шаг 5, изображение 1 из 3 Why! NH57ADS Fan and Heatsink Removal, Fan and Heatsink Assembly: шаг 5, изображение 2 из 3 Why! NH57ADS Fan and Heatsink Removal, Fan and Heatsink Assembly: шаг 5, изображение 3 из 3
    • Remove the two Phillips screws securing the left hand fan.
    • Remove the six Phillips heatsink retaining screws .
    • Using the two black tabs as handles, lift and remove the heatsink.
Заключение
To reassemble your device, follow the instructions in reverse order.
Особая благодарность этим переводчикам:
fr en
50%
Jerry Wheelerпомогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Felice Suglia
Участник с: 06/15/13
30 908 Репутация
Автор 264 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 93
