Wii Balance Board Battery Case Replacement
Выберете то, что вам нужно
  1. Wii Balance Board Battery Case Replacement, Unscrewing the Foot Cover: шаг 1, изображение 1 из 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Battery Case Replacement, Removing the Foot Cover: шаг 2, изображение 1 из 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Battery Case Replacement, Removing the Foot: шаг 3, изображение 1 из 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Battery Case Replacement, Removing the Additional Feet: шаг 4, изображение 1 из 1
    • Repeat steps two and three on the remaining four feet.
    how to completely remove and then put back in would be helpful as that's what the title of this post is…. right?
    Nelda Murray - Ответить
  5. Wii Balance Board Battery Case Replacement, Unscrewing the Back Cover: шаг 5, изображение 1 из 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Battery Case Replacement, Removing the Back Cover: шаг 6, изображение 1 из 1
    • Lift off the gray back cover.
    Top Anleitung, aber kann nirgends die Platine finden.... Könnt ihr da helfen? Danke!!!
    Dominik - Ответить
  7. Wii Balance Board Battery Case Replacement, Battery Compartment: шаг 7, изображение 1 из 2 Wii Balance Board Battery Case Replacement, Battery Compartment: шаг 7, изображение 2 из 2
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Battery Case Replacement, Removing the Battery Case: шаг 8, изображение 1 из 1
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
    Just wanted to say THANKS it really helped & saved me having to get a new one or repaired. u rock! Sending good karma your way!
    scottydecept - Ответить
    Were can I get a battery case replacement holder for my wii fit balance board
    Jacqueline Booth - Ответить
    Do we wipe down something after that?
    Kandace Lavender - Ответить
    New batteries. Start “button" blinks, then turns off. Any suggestions?
    Ginny Butler - Ответить
    After removing it I soaked the battery case in vinegar for maybe 30 minutes. A little toothbrush work and all of the crap was gone. Rinsed it, dried it, put it back in. While it soaked I also used vinegar on the spring battery terminal that is cabled to the base. Cleaned up very nicely.
    jatrac1 - Ответить
Заключение
16 участников успешно повторили данное руководство.
Michelle Reed
Участник с: 09/29/14
447 Репутация
1 руководство автора
Команда
Cal Poly, Team 13-8, Forte Fall 2014 Участник Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 членов
Автор 15 руководств
14 Комментариев
I unscrewed everything, but were do i find a replacement battery compartent?
Olivia C - Ответить
Then what do you do after you remove the battery case?
CRAIG WIKMAN - Ответить
Is there a way to open the top of the board by sliding or lifting the top? I bought a gently used wii fit. The lady who sold it to me very quickly opened the top of the board from the centre seam to show me the instruction manual and I think hook up cables. I cannot, for the life of me figure out how she did it! Any ideas or technical wizardry you can share?
Frustrated in Canada!
Pam Murray - Ответить
u rock - it totally worked
Why tell to remove all those parts and then there's no replacement battery board
Valerie Triplin - Ответить
Thanks for this. i bought the replacement battery compartment a while ago but didn’t dare try to do it. Your instructions were clear to follow, so I did it in 20 mins. Thanks again.
Fire Storm - Ответить
Hi there where did you get the replacement battery compartment from please? Thanks
helenhodson -
Can you please let us know where to purchase the replacement battery compartment?
daviddames -
Where can I find a replacement battery board?
Frederick Bergeron - Ответить
Any link to a replacement compartment?
Kizzy Worth - Ответить
Can be helpful if you need to clean the battery holder after the battery has leaked, rather remove the battery box than put liquid near the pcb's. - thanks!
Alan Harrison - Ответить
What you do next is… check Amazon for a GameOn Fit Balance Rechargeable Battery Pack (Wii) , then look at Ebay to find one at half the price!
Lawrence Armour - Ответить
I want remoot from wherei can get one ?
محمد ابورزق - Ответить
wo kann ich ein neues Batteriefach dafür, kaufen??. antwort bitte auf :batascheen@gmail.com:
Renate Herbst - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 63
За последние 30 дней: 262
За всё время: 41,672
