Введение
This guide will demonstrate how to replace the Power Supply inside the Wii Balance Board.
Выберете то, что вам нужно
Flip device upside-down so the plastic white board is facing the ground.
Locate the four feet in the corners of the Balance Board.
Unscrew the three 12.7 mm Phillips screws from each foot cover.
Remove the gray plastic ring from the actual foot by lifting it up.
Repeat steps two and three on the remaining four feet.
Locate the gray battery compartment.
Push the tab on the bottom and lift up completely to remove the cover to the batteries.
Unscrew the two 6.35 mm Phillips #1 screws.
Slide the battery case out.
Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
Еще один человек закончил это руководство.
2 Комментарии к руководству
Top Anleitung, aber wo kann ich die Platine herbekommen? Danke!!!
Hi, My batteries leaked over the UART_RX pin and I don't know how to fix it
