Wii U GamePad Battery Replacement
Выберете то, что вам нужно
  1. Wii U GamePad Battery Replacement, Battery: шаг 1, изображение 1 из 2 Wii U GamePad Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Battery Replacement: шаг 2, изображение 1 из 3 Wii U GamePad Battery Replacement: шаг 2, изображение 2 из 3 Wii U GamePad Battery Replacement: шаг 2, изображение 3 из 3
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
Заключение
22 участников успешно повторили данное руководство.
Kim Arre
Участник с: 01/11/13
4 918 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 17-20, Forte Winter 2013 Участник Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 членов
Автор 38 руководств
7 Комментариев
I only see two pins on most 3rd party rechargeable Li-Ion batteries. What is the pinout for the factory supplied battery? I would like to replace the battery with a similar 3.7v Li-Ion battery from somewhere like adafruit.
roof tip - Ответить
I found an answer to my first question. My follow up question is if you can use a battery with only two charging pins and not the temp sensor pins?
roof tip - Ответить
There's no reason you can't but without the temp sensor you must be cautions if your battery does over heat because it can lead to damages on the touchscreen as well.
Steven Chiu - Ответить
Why does Nintendo mention a size #0 screwdriver while iFixit says #00?
proof: http://en-americas-support.nintendo.com/...
"•Use a crosshead style, size #0 screwdriver to avoid damage to the screw or threads"
"2.Loosen the battery cover screws with a crosshead style, size #0 screwdriver."
/a confused person
Chris - Ответить
The size #00 is just a little smaller than the #0. When we wrote these guides, we used whatever worked for us. Either should work, but generally you should use the largest that will work to avoid stripping the screw.
Kim Arre -
can't you just use any lithium battery like this?? It shouldn't have to be a special exclusive device only battery.
jasonmg99 - Ответить
Great idea! Maybe you can try it out and let us know if it works or not!
stevenychiu -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 19
За последние 7 дней: 100
За последние 30 дней: 579
За всё время: 31,496
