Wii U GamePad Battery Replacement
Выберете то, что вам нужно
  1. Wii U GamePad Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Battery Replacement: шаг 2, изображение 1 из 1
    • Lift and remove the battery plate.
  3. Wii U GamePad Battery Replacement: шаг 3, изображение 1 из 3 Wii U GamePad Battery Replacement: шаг 3, изображение 2 из 3 Wii U GamePad Battery Replacement: шаг 3, изображение 3 из 3
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
Заключение
24 участников успешно повторили данное руководство.
Valentina Cerruty
Участник с: 02/10/16
3 345 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 1-6, Sullivan Spring 2016 Участник USF Tampa, Team 1-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G6
4 членов
Автор 40 руководств
3 Комментариев
I'm trying to put in the new battery, but the connector won't snap in even with larger amounts of force. The original battery, on the other hand, snaps right in.
ToastyGhost - Ответить
I have the same issue. The connector on the new battery does not snap in. Does anyone know how to fix this issue and ger the connector to snap into place?
Encom - Ответить
It takes a significant amount of pressure (in my opinion) to get the ifixit wii u gamepad battery to snap into place. When I successfully installed this battery, I laid the wii u gamepad screen down with the top of the gamepad facing me. Then I took the flat end of my ifixit spudger, and while pressing down on the battery connector at a 45 degree angle, I pushed the battery connector into the port. You'll be able to tell when the battery is connected all the way. However, this battery does NOT make a snap or click sound to let you know it's connected all the way.
Link to the spudger I used: Spudger
RakmanII -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 17
За последние 7 дней: 112
За последние 30 дней: 624
За всё время: 12,765
