Введение
This guide will help you to replace the LCD display. For this replacement, you will need to use a #00 Phillips screwdriver and a small tri-point (Y) screwdriver.
Выберете то, что вам нужно
Видеообзор
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
With your finger, press down and pull back on the battery connector plug.
Remove the battery from the battery case.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
Unplug outer case rumble motor connector from the motherboard with your fingers.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the right speaker cable that's connected to the motherboard with the tweezers.
Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
Remove the white flex cable with the tweezers.
Disconnect the analog connector with tweezers.
Carefully lift the black clasp. It is prone to breaking if only lifted from one point. Remove the brown ribbon by using the tweezers.
Unclasp and release the small digitizer ribbon cable to the left of the brown ribbon.
Remove the remaining three 5.1 mm screws using the Phillips size #0 screwdriver.
Lift and remove the mother board.
Remove the four 5.1mm screws using Phillips size #0 screwdriver.
Pull the white and black cables away from the display case.
Gently with your fingers, press on the front of the display and it will lift up.
Remove the display with your fingers.
86 человек успешно провели ремонт по этому руководству.
20 Комментарии к руководству
was really perfect to repair my device. Thank you very much for this help
In step 14 - what does the small gray ribbon do? The replacement LCD display that I got in the mail did not have it.
Its the touch screen cable. The screen I ordered did not come with one. I had to carefully remove it from my broken display and put it on the new one. Thankfully the touchscreen still works for me.
Mine did not come with the touch screen either.
