Введение
This guide will help you to replace the speakers if you are experiencing audio issues.
Выберете то, что вам нужно
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
With your finger, press down and pull back on the battery connector plug.
Remove the battery from the battery case.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
Unplug outer case rumble motor connector from the motherboard with your fingers.
I agree. A circle over the plug would have been better as the picture looks like you just pull on the wires lol.
Chris -
Thanks for the comment. I did get a set of tweezers and the negative cable broke anyway. They really could have done a better job at using a different connector for that.
Why in the world is this thing so tightly connected?
Thanks for the comment. I did get a set of tweezers to try to pull it out but still ended up breaking the negative cable. They really could have used a better set of cables and connectors for this.
With your fingers, unplug the left speaker cable from the motherboard.
Speakers are connected with solder so removing them is not possible without requiring soldering later on. I left them both connected and instead of removing the motherboard completely I just "hinged" it carefully down to facilitate the work following step 18.
Thank you for offering this info because I spent 20 minutes between scratching my head and searching for any alternatives to just the image above, which had a wire nut/housing (and mine certainly did not). As I began to have an anxiety attack (
Mine also did not have connectors for the speaker. But like mentioned above, I was able to do repair WITHOUT the need to unsolder the speaker wires. Thanks!
Remove the right speaker cable that's connected to the motherboard with the tweezers.
Note that on some units (presumably later ones), the speakers are soldered onto the motherboard.
6 участников успешно повторили данное руководство.
Один комментарий
Awesome guide, replacement speakers worked flawlessly!!
tried to unscrew the 10 Tri-Wing size Y1 screw with my iFixIt toolkit
unfortunately the tool is too “fat” and short, it cannot reach 4 screws on the corners of the gamepad.
having the iFixIt toolkit and needing to purchase an additional slim screwdriver it’s a shame…
Antonello Iannone - Ответить
