Windsor Willow Rear Wheel Replacement
  1. Windsor Willow Rear Wheel Replacement, Chain: шаг 1, изображение 1 из 1
    • The chain connects the crank arm to the gear cluster on the back wheel.
  2. Windsor Willow Rear Wheel Replacement: шаг 2, изображение 1 из 1
    • On the chain, locate the master link. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
  3. Windsor Willow Rear Wheel Replacement: шаг 3, изображение 1 из 2 Windsor Willow Rear Wheel Replacement: шаг 3, изображение 2 из 2
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
  4. Windsor Willow Rear Wheel Replacement: шаг 4, изображение 1 из 1
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
  5. Windsor Willow Rear Wheel Replacement, Rear Wheel: шаг 5, изображение 1 из 1
    • Hold the bicycle so that the bicycle wheels rests in the air and able to stand on its own.
  6. Windsor Willow Rear Wheel Replacement: шаг 6, изображение 1 из 2 Windsor Willow Rear Wheel Replacement: шаг 6, изображение 2 из 2
    • Open the sidepull brakes by fully rotating the title lever on the brake upwards.
  7. Windsor Willow Rear Wheel Replacement: шаг 7, изображение 1 из 2 Windsor Willow Rear Wheel Replacement: шаг 7, изображение 2 из 2
    • To loosen the wheel, simply pull out the lever, away from the frame and loosen up.
  8. Windsor Willow Rear Wheel Replacement: шаг 8, изображение 1 из 1
    • When the quick release is opened, the wheel is ready to remove.
Заключение
Zin
Участник с: 01/26/17
102 Репутация
1 руководство автора
Команда
Cal Poly, Team 10-6, Banghart Winter 2017 Участник Cal Poly, Team 10-6, Banghart Winter 2017
CPSU-BANGHART-W17S10G6
5 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 159
