Введение
in order to complete this guide, you will need to remove the battery, put a new one in its place, and solder the new connections onto the motherboard.
Выберете то, что вам нужно
Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
Un-stick the battery from the motherboard assembly with the plastic opening tool.
Инструмент, используемый на этом этапе:Tweezers$4.99
Desolder the battery wires from the motherboard.
To reassemble your device, glue the new battery to where the old one was and solder the new power connectors where the old ones were. Then follow the instructions in reverse order.
3 человек успешно провели ремонт по этому руководству.
