Введение
To complete this guide, you will need to take apart the tablet almost completely.
Выберете то, что вам нужно
Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
Un-stick the battery from the motherboard assembly with the plastic opening tool.
Инструмент, используемый на этом этапе:Tweezers$4.99
Desolder the battery wires from the motherboard.
Remove each of the four 4 mm screws from the motherboard pictured to the left.
Use a Phillips #00 precision screwdriver.
Use the spudger to pry the instrument array from its plastic housing.
Slowly slide the spudger underneath the adhesive tape to un-sitck it.
Be careful not to harm the array of wires leading to this tape.
De-tatch the motherboard output wires from the screen using the tweezers.
There are two additional 4 mm screws holding the front screen.
Use the Phillips #00 screwdriver to remove the screws (pictured to the left).
1 Комментарий к руководству
Hi, have a Filemate tablet and the front is broke . So is the Front and Digitizer the same thing? Thank you Brenda L Glidewell
