Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Wire needs to be exposed from its insulation in order before it can be soldered to another wire. Wire stripping exposes the wire so you are able to make good connections.
Выберете то, что вам нужно
While squeezing, pull the stripper along the end of the wire. This should expose some of the wire by removing its insulation.
After your wire has been stripped, the exposed wire is ready to be soldered and reconnected to other parts of the microphone.
8 участников успешно повторили данное руководство.
