Wireless Xbox One Controller Bumper Assembly Replacement
Выберете то, что вам нужно
  1. Wireless Xbox One Controller Bumper Assembly Replacement, Bumper Assembly: шаг 1, изображение 1 из 1
    • Remove the battery cover from the back of the controller by sliding it upwards.
  2. Wireless Xbox One Controller Bumper Assembly Replacement: шаг 2, изображение 1 из 3 Wireless Xbox One Controller Bumper Assembly Replacement: шаг 2, изображение 2 из 3 Wireless Xbox One Controller Bumper Assembly Replacement: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Halberd Spudger
    $2.99
    • Using the halberd spudger, pry the grip casing upwards from the handle.
    • Remove the grip casing from both the left and right handles of the controller.
    • It helps to begin near the top of the grip casing near the trigger.
  3. Wireless Xbox One Controller Bumper Assembly Replacement: шаг 3, изображение 1 из 2 Wireless Xbox One Controller Bumper Assembly Replacement: шаг 3, изображение 2 из 2
    • Remove the five 9 mm Torx TR9 security screws from the top and bottom of the controller grip regions as well as from the center of the battery region.
    • The pins on the security screws can be broken off easily with a small flathead screwdriver for use of an ordinary Torx screwdriver if the security version is unavailable.
  4. Wireless Xbox One Controller Bumper Assembly Replacement: шаг 4, изображение 1 из 1
    • Remove the back of the controller casing by lifting it up and off.
  5. Wireless Xbox One Controller Bumper Assembly Replacement: шаг 5, изображение 1 из 1
    • Lift the internal assembly from the plastic controller case.
    • Handle gently; the motors on the bottom left and right are not firmly attached.
  6. Wireless Xbox One Controller Bumper Assembly Replacement: шаг 6, изображение 1 из 2 Wireless Xbox One Controller Bumper Assembly Replacement: шаг 6, изображение 2 из 2
    • Remove the top button panel from the controller by gently lifting up the hooks attached to the internals.
  7. Wireless Xbox One Controller Bumper Assembly Replacement: шаг 7, изображение 1 из 1
    • Detach the bumper assembly by sliding one bumper to the side away from the controller and then lifting upwards.
    • Gently follow the motion indicated by the arrows.
  8. Wireless Xbox One Controller Bumper Assembly Replacement: шаг 8, изображение 1 из 1
    • Remove bumpers and replace by inserting a new bumper assembly.
Заключение
14 человек успешно провели ремонт по этому руководству.
Patrick Ashman
Участник с: 01/30/23
384 Репутация
1 руководство автора
Команда
Cal Poly, Team 2-2, Johann Winter 2023 Участник Cal Poly, Team 2-2, Johann Winter 2023
CPSU-JOHANN-W23S2G2
3 членов
Автор 3 руководств
1 Комментарий к руководству
hie my controller vibrate and goes off immediately I start using it kindly assist
Shakes makena - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 20
За последние 7 дней: 126
За последние 30 дней: 504
За всё время: 14,130
