Wolf Gourmet WGTR102S Slide Assist Plunger Replacement
Выберете то, что вам нужно
  1. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement, Outer Shell: шаг 1, изображение 1 из 1
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: шаг 2, изображение 1 из 1
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: шаг 3, изображение 1 из 1
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: шаг 4, изображение 1 из 1
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: шаг 5, изображение 1 из 1
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: шаг 6, изображение 1 из 1
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: шаг 7, изображение 1 из 1
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: шаг 8, изображение 1 из 2 Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: шаг 8, изображение 2 из 2
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement, Slide Assist Plunger: шаг 9, изображение 1 из 1
    • Remove the top panel by bending the tabs on each side straight up.
  10. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: шаг 10, изображение 1 из 1
    • Remove the two 8mm screws on the bottom of the plunger using a Tri-point Y1 screwdriver.
  11. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: шаг 11, изображение 1 из 2 Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: шаг 11, изображение 2 из 2
    • Remove the plunger from the device.
Заключение
Еще один человек закончил это руководство.
Ryan Funchess
Участник с: 04/19/18
697 Репутация
Автор 5 руководств
Команда
Cal Poly, Team S22-G5, Maness Spring 2018 Участник Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
4 членов
Автор 5 руководств
4 Комментариев
Where does one get a new plunger for the replacement?
hsernaker - Ответить
yes, where does one get a new pludger?
hiyar124 - Ответить
Has anyone found a source for the WOLF toaster plunger?
Rick Guest - Ответить
Any pointers on where to find Wolf replacement parts ?
Stefano Concina - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 29
За всё время: 1,092
