Введение
A broken fence may cause many issues, such as your pet getting out, the pesky home owners association giving you a fine, or maybe you just do not like the way it looks. Replacing a picket on a wooden fence is much easier than it seems, and this guide is here to prove that. With just a few simple steps and a quick run to the hardware store, you will have that picket replaced in no time.
Before completing the rest of this guide, complete Step 1. This is needed to get the measurements of the picket you are replacing so you can purchase a replacement.
This materials listed in this guide reflect the materials needed to replace a single picket. For every additional picket being replaced, add 6 x 2 1/2” Wood Nails.
Выберете то, что вам нужно
Use the tape measure to measure the height, width, and depth of the picket.
Place the tip of the pry bar under the picket, in line with the nails.
Use a hammer to push the pry bar under the picket.
Pull the pry bar away from the fence to remove the picket.
Only complete this step if there are still nails in the wood after you have removed the picket. If all nails are removed, continue to Step 4.
Slide the claw of the hammer underneath the nail.
While holding the handle, pull on the hammer to remove the nail.
Before installing the new picket, clear the area of any debris.
Use the tape measure to measure the gaps between the left and right side of the picket.
Hold a wood nail approximately 1 inch from the side of the picket.
You may place the first nail 1 inch away from either the left or right side of the picket. Each section uses 2 nails so it does not matter which side you choose to work on first.
Lightly tap on the wood nail with the hammer to begin pushing the nail into the picket. Continue until the nail is fully in the picket.
Repeat until there are 2 nails inserted in the picket at every cross section.
This guide only demonstrates how to replace a picket on a wooden fence. For questions regarding staining your fence and finding the right stain, I recommend talking with a worker at a hardware store near you. They can help you find the right product and make sure your new picket matches the rest of your fence.
