Введение
If the device does not start and the Sensor Lens is in good condition, then the Circuit Board may be faulty and need replacement.
  1. Begin by removing both screws and the brushed metal casing. Simply lift up at the indicated area with your hand. The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws. The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws.
    • Begin by removing both screws and the brushed metal casing. Simply lift up at the indicated area with your hand.
    • The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws.
  2. Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom. Lift the grey belt away. This gives access to the server board.
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  3. Remove all three 1/2" Ph1 screws connecting the server board to the device. During reassembly, install the screws before reattaching the wires. During reassembly, install the screws before reattaching the wires.
    • Remove all three 1/2" Ph1 screws connecting the server board to the device.
    • During reassembly, install the screws before reattaching the wires.
  4. Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board. Use the same tool to dislodge the white capped ribbon bus with the multi-colored wires. After these steps, the server board should easily come off the side of the device.
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
    • Use the same tool to dislodge the white capped ribbon bus with the multi-colored wires.
    • After these steps, the server board should easily come off the side of the device.
Заключение
Blane Hirsh
Участник с: 17.09.2018
260 Репутация
Автор 2 руководств
Команда
Washington State, Team S1-G6, Hope Fall 2018 Member of Washington State, Team S1-G6, Hope Fall 2018
WSU-HOPE-F18S1G6
4 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 67
