Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If the device does not start and the Sensor Lens is in good condition, then the Circuit Board may be faulty and need replacement.
Выберете то, что вам нужно
Begin by removing both screws and the brushed metal casing. Simply lift up at the indicated area with your hand.
Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
Lift the grey belt away. This gives access to the server board.
Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
Use the same tool to dislodge the white capped ribbon bus with the multi-colored wires.
After these steps, the server board should easily come off the side of the device.
