Введение
The Wyze Cam V2's speaker is responsible for producing sound and is an important part of the system. If your cam's audio is muffled or completely absent, the speaker may need to be replaced. This guide will help walk you through the steps of replacing a non-functioning speaker.
Выберете то, что вам нужно
Open up the camera stand to expose the bottom plate of the camera.
Remove two 4 mm silver screws using the Phillips #0 screwdriver.
Using the iFixit opening tool, carefully pry open the bottom plate to gain access to the camera's internals.
Open up the back panel using the iFixit opening tool and unclip the panel from the rest of the device.
Инструмент, используемый на этом этапе:Tweezers$3.99
Using the angled slim tweezers, disconnect the cord and pull it gently off of the motherboard.
Remove the two 6 mm screws from the back cover with a Phillips #0 screwdriver.
Carefully lift off the speaker plate.
