Введение
If the battery of your Wyze WVCR200s robot vacuum isn't charging or won't hold a charge, you may need to replace the battery. This guide demonstrates how to replace the battery of your Wyze WVCR200s. Start off by checking the connection from the battery to the port. For your safety, make sure the device in fully powered down before attempting to remove the battery.
Выберете то, что вам нужно
Pinch the blue tabs below the rotating brush towards each other.
Lift the plastic housing surrounding the rotating brushing straight up, and the remove it from the vacuum.
Use a screwdriver to remove four screws along the edge, just above where the brush was removed.
Lift the battery out from underneath the cover.
Carefully disconnect the battery from the vacuum port.
Еще один человек закончил это руководство.
