Введение
Before proceeding, make sure you have all the necessary parts and tools for this replacement guide. This is over the replacement of the motherboard for XTreme Tablet Generation 2. If you feel the need, use safety glasses and gloves when applicable.
Выберете то, что вам нужно
Remove the cover from the back of the tablet. Using the pick tool, pry the cover the case. Do this by starting in the upper corner, working around the edges until the cover unclips from the case.
Инструмент, используемый на этом этапе:Desoldering Pump$3.99
Find and detach all of the connections to the motherboard. Remove the connections while leaving the components in place from the battery, camera, ground wire, plastic connections at the charging port, and the 512MB DDR3 SDRAM.
Replacing the defective motherboard with a functional motherboard: Reattach the connections at the battery, camera, ground wire, plastic connections at the charging port, and the 512MB DDR3 SDRAM.
