Введение
The headlights illuminate while the car is moving forward, and can be useful for seeing the road ahead. A disconnected wire or blown light will make the light not die and will need replacing.
Выберете то, что вам нужно
Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
Unclip the two clips to remove the battery cover.
Unscrew the two 2.5 mm Phillips #00 screws from the underside of the car and remove the front underskirt.
Unscrew the four 2.5mm Phillips #00 screws from the front bumper and lift up the front bumper to remove.
Еще один человек закончил это руководство.
