Введение
The motherboard controls all actions of the RC car including steering, acceleration, and communication with the remote. A faulty motherboard will lead to many glitches and unresponsive action in all involved systems.
Выберете то, что вам нужно
Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
Unclip the two clips to remove the battery cover.
Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
Lift the main underbody from the shell of the car.
Lift up the body to expose the wiring and hardware underneath.
Desolder all wires connected to the motherboard.
In this step, you will have to take great care in keeping track of the wires
Our suggestion is to attach tape to each wire, and letter the tape. Letter each tape according to the respective lettering found on the motherboard.
Unscrew the two 1.6mm Phillips #000 screws connecting the motherboard to the under body of the car.
2 участников успешно повторили данное руководство.
