Введение
The steering column spring is responsible for reverting the wheels to a straight position when the remote is not turning one way or the other. A faulty steering column spring will fail to default to the straight position after turning the wheel.
Выберете то, что вам нужно
Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
Unclip the two clips to remove the battery cover.
Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
Lift the main underbody from the shell of the car.
Lift up the body to expose the wiring and hardware underneath.
Unscrew the three 2.5mm Phillips #00 screws from the white steering column.
Remove the three 1.6mm Phillips #000 screws from the black motor casing.
Еще один человек закончил это руководство.
