Введение
The wheels connect the car to the ground. Any fault in these could hinder the car performance and replacing them would serve to improve the car.
Выберете то, что вам нужно
Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
Unclip the two clips to remove the battery cover.
Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
Lift the main underbody from the shell of the car.
Lift up the body to expose the wiring and hardware underneath.
Unscrew the three 2.5mm Phillips #00 screws from the white steering column.
