Xbox 360 Bottom Vent Replacement
Выберете то, что вам нужно
  1. Xbox 360 Bottom Vent Replacement, Bottom Vent: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Xbox 360 Opening Tool
    Купить
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
    You can avoid this step by pulling the front cover off. Just make sure you don't break the springs for the USB bay area.
    Repair Doctor - Ответить
    Hello, thank you ifix for this guide, I followed this guide, I got stuck at some point but I resolved it. Also I want to share this resource: Step by Step guide to fix Xbox 360 errors it helped me go through all the things associated with Xbox 360 and the troubleshooting of errors. Hope this can also help you all.
    Christopher Sage - Ответить
  2. Xbox 360 Bottom Vent Replacement: шаг 2, изображение 1 из 3 Xbox 360 Bottom Vent Replacement: шаг 2, изображение 2 из 3 Xbox 360 Bottom Vent Replacement: шаг 2, изображение 3 из 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
  3. Xbox 360 Bottom Vent Replacement: шаг 3, изображение 1 из 2 Xbox 360 Bottom Vent Replacement: шаг 3, изображение 2 из 2
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
  4. Xbox 360 Bottom Vent Replacement: шаг 4, изображение 1 из 2 Xbox 360 Bottom Vent Replacement: шаг 4, изображение 2 из 2
    • Repeat the same process to release the two center clips on the bottom vent.
  5. Xbox 360 Bottom Vent Replacement: шаг 5, изображение 1 из 2 Xbox 360 Bottom Vent Replacement: шаг 5, изображение 2 из 2
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
  6. Xbox 360 Bottom Vent Replacement: шаг 6, изображение 1 из 1
    • Remove the bottom vent from the 360.
Заключение
68 участников успешно повторили данное руководство.
Один комментарий
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 15
За последние 30 дней: 97
За всё время: 28,150
