Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
When you can't download the game you just have to have follow this guide to replace your Wi-Fi card.
Выберете то, что вам нужно
Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
Pull the top panel off.
Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
5 участников успешно повторили данное руководство.
