Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide is an internal guide used as a prereq.
Запчасти
Детали не указаны.
  1. Insert the flat edge of a spudger between the faceplate and the outer casing near the power button. Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
    • Insert the flat edge of a spudger between the faceplate and the outer casing near the power button.
    • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
    • You may also accomplish this task by using the edge of the Xbox 360 opening tool, but it may scratch the plastic case.
    • Alternatively, you can use your hands to carefully pull the faceplate away from the Xbox.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Repeat the same motions as previously mentioned to release the left side of the faceplate.
    • Repeat the same motions as previously mentioned to release the left side of the faceplate.
  4. Remove the faceplate from the front face of the console.
    • Remove the faceplate from the front face of the console.
Заключение
Еще один человек закончил это руководство.
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 851
