Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide is used as an internal prereq.
Peel the silver tape securing the optical drive to the metal casing.
Slightly lift the optical drive upwards to gain clearance to disconnect the SATA and power connectors located on the backside of the optical drive.
Grab the power connector by its cables and pull it straight out of its socket on the optical drive.
Disconnect the SATA data connector from its socket on the optical drive by pulling it straight away.
