Xbox 360 Wireless Controller Left Analog Stick Replacement
Выберете то, что вам нужно
  1. Xbox 360 Wireless Controller Left Analog Stick Replacement, Left Analog Stick: шаг 1, изображение 1 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement, Left Analog Stick: шаг 1, изображение 2 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement, Left Analog Stick: шаг 1, изображение 3 из 3
    • The left stick is the most common one to go bad.
    • Depress the battery release button on the top of the controller. Remove the battery holder from the controller.
    • Use tweezers or similar instrument, to peel the barcode sticker from the battery compartment.
  2. Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 2, изображение 1 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 2, изображение 2 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 2, изображение 3 из 3
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
    • Insert a plastic opening tool between the front and rear cases along the left edge of the controller. Rotate the tool toward the front of the controller to pry the two cases apart.
    • Grasp the controller by the battery compartment and the headphone jack. Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
  3. Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 3, изображение 1 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 3, изображение 2 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 3, изображение 3 из 3
    • Tilt the bottom case slightly toward the trigger buttons to slide it off the top case
    • Here is a view of the inside of the controller. Note the vibration motors having different counter weights.
    • Remove the connector from the left motor (controller is positioned upside down, left controller will be shown right etc.)
  4. Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 4, изображение 1 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 4, изображение 2 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 4, изображение 3 из 3
    • Remove the connector from the right motor
    • Both motors are disconnected. Notice position of the motors inside the case for re-assembly.
    • Remove logic board
  5. Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 5, изображение 1 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 5, изображение 2 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 5, изображение 3 из 3
    • Notice placement of rubber membranes on the front case for reassembly.
    • To remove the covers of the analogs sticks, simply pull them from the mounting pegs.
    • View of the left analog stick to be removed.
  6. Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 6, изображение 1 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 6, изображение 2 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 6, изображение 3 из 3
    • To remove the left analog stick, the left trigger button will have to be removed first. Desolder the three solder points. Use desoldering wick and some flux to remove the solder.
    • Left trigger points unsoldered.
    • There are 2 snaps holding the left trigger piece in place, remove those. It may take a bit of force, but simply push the snap over and down.
  7. Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 7, изображение 1 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 7, изображение 2 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 7, изображение 3 из 3
    • When removing the left trigger, make sure that the points are unsolderd properly, gently pull the trigger downward.
    • Left trigger removed.
    • With the left trigger removed, simply turn the logic board over and find the 14 solder connections
  8. Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 8, изображение 1 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 8, изображение 2 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 8, изображение 3 из 3
    • Use a desoldering wick and some flux to remove the solder.
    • Ensure that no other components get either desoldered or otherwise heat damaged.
    • Here, all points have been desoldered.
  9. Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 9, изображение 1 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 9, изображение 2 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 9, изображение 3 из 3
    • Pull off the 3D analog stick gently to ensure that all solder connections are unsoldered.
    • Remove the analog stick
    • Put the new 3D analog stick in place. Make sure that it is seated flush against the board.
  10. Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 10, изображение 1 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 10, изображение 2 из 3 Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 10, изображение 3 из 3
    • Apply some flux to the solder points and the leg of the analog stick.
    • Solder the connections in place.
    • All points soldered back in place. The liquid black debris is flux. This can be removed by cleaning the board with some isopropyl alcohol after the soldering.
  11. Xbox 360 Wireless Controller Left Analog Stick Replacement: шаг 11, изображение 1 из 1
    • Here is the board with the new sticks and the left trigger button resoldered.
Заключение
43 участников успешно повторили данное руководство.
oldturkey03
Участник с: 09/29/10
782 216 Репутация
Автор 119 руководств
Команда
Global Fixers Участник Global Fixers
Community
33 членов
Автор 537 руководств
14 Комментариев
My controller left stick is physically okew..but in gaming it is moving on downwards...
How can I fix this,I don't knew to do this repairing!:(
Mohamed Irfan - Ответить
I would like to note, you can unscrew the security screws with a 00 Flat head screwdriver. I just did it now and got all the screws out. Just gotta find the sweet spot, but it works.
gickygouse19 - Ответить
Where do you purchase the actual 2-axis module that get resoldered to the board?
ivymaccurtin - Ответить
muy buen tutorial, ¿¿¿no te sabras los valores de los condensadores c5 y c71??? es que tube un incidente y los arranque los dos.
un saludo
David Martin - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 87
За последние 30 дней: 334
За всё время: 105,914
