Запчасти
Детали не указаны.
  1. Depress the battery release button on the top of the controller. Remove the battery holder from the controller.
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Use a pair of tweezers to peel the barcode sticker from the battery compartment.
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Remove the seven 9.3 mm  T8 Security Torx screws securing the rear case to the front case.
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  4. Insert a spudger between the front and rear cases, near the headphone jack. Rotate the spudger toward the front of the controller to pry the two cases apart.
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  5. Grasp the controller by the battery compartment and the headphone jack. Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  6. Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board. Lift the vibration motor out of the front case.
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  7. Remove the vibration motor from the other side of the controller using the same method previously described. The left motor has significantly more counterweight than the right motor.
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  8. Lifting from the headphone jack and power plug, remove the logic board from the front case. Lifting from the headphone jack and power plug, remove the logic board from the front case.
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
Заключение
Brett Hartt
Участник с: 12.04.2010
121 408 Репутация
Автор 143 руководств
Команда
iFixit Участник iFixit
Community
137 членов
Автор 16 041 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,078
