Введение
Similar to the buttons, triggers can break during hardcore gaming or could lose functionality due to sticky and gooey substances (eg. food). In this guide, you will learn how to replace the left and right triggers of the controller. This guide involves opening the controller.
Выберете то, что вам нужно
Turn the controller on its backside and push the "eject" button to discharge the battery compartment door on the bottom of the controller.
Pull the two AA batteries out.
Insert a spudger and pry at these three locations to detach the middle cover.
Pull off the middle piece cover to reveal three screws.
Use a T8 Torx screwdriver to remove the three 2.3mm screws.
Remove the cover.
Remove the two 90mm screws with a T8 Torx screwdriver.
Lift up the silver middle piece to remove.
Use a spudger to remove the silver prong.
With the spudger, pinch the metal spring and slowly pull up to remove.
Use the spudger to remove eject button.
Remove the screw holding in the eject button with a T8 Torx screwdriver.
Pull the two halves apart at the bottom to detach the two latches that are holding the front and back panels together.
Start with one side of the controller (left or right).
Slide the spudger towards the end of the handles and pry the two halves apart. Do the same for the opposite side.
Pull the front and back panels apart to separate them and expose the inside of the controller.
Use a T6 Torx screwdriver to remove the four 2.3mm screws.
Lift up the black locking tab on the ZIF connector to release the ribbon cable.
Lift up the trigger to remove it from the controller.
Repeat for the other trigger.
Один комментарий
Where can I buy the Where can I buy the spare or replacement trigger?
