Введение
This guide walks people with a hobbyist-level skill and interest in electronic repair through the steps necessary to tear down and clean an Xbox series 1 Elite controller. The colored bullet points in the steps are associated with the matching colored circles in the accompanying visuals.
Выберете то, что вам нужно
Expel the remaining electricity by pushing and holding the home button down for several seconds once the battery has been removed.
Removing the thumbsticks and D-pad will make the rest of the teardown smoother.
Using a soft pry tool, start from the top near the triggers and work your way down prying, and loosening the grips until they are removed.
Remove the 4 T8 screws that were covered by the rear grips.
Remove the T8 screw behind the sticker in the battery compartment.
Wiggle the edges of the front housing shell to work it free. It will then come off with little effort.
Remove the joysticks and selector switch.
The audio input jack catches on the rear housing shell. Lightly pry the shell around the jack while pulling up on the midframe to remove it.
Wiggle and pull the ribbon away from the connector.
Remove the retaining ring and the D-pad.
The retaining ring is clipped in. Lightly pull back and up to remove.
Remove the bumpers by pushing down on the ends and lifting outward to unclip them. Then, holding from the middle, wiggle the rest free while pushing the home button down.
Desolder both sets of rumble motor wires and trigger wires from the back of the daughter board.
Remove the 2 T6 screws from the back of the daughterboard
Slowly and carefully work the pry tool evenly around the daughterboard, and between the midframe Lightly pulling out on it until it disconnects.
Set the audio input jack aside
Remove the 6 T6 screws from the main board.
Once the screws are removed, the board can be pulled straight out and set to the side.
Remove the grey rubber button backing and remove the buttons, and move them to the side.
